SOT89 Package Footprints |
m.elsayed
Topic: SOT89 Package FootprintsPosted: 2 hours 57 minutes ago at 7:07am |
Part Number: PXT2907A,115 Case Code: SOT89 Manufacturer: Nexperia Supplier link: https://www.nexperia.com/product/PXT2907A Pad Shape is flat and can't find this shape in the Surface Mount component families. |
Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 5975 |
Posted: 1 hour 22 minutes ago at 8:42am |
The Nexperia PXT2907A,115 is on www.pcblibraries.com/POD
It's available for free download. Components with irregular shaped pad stacks are created in a CAD tool and imported in the FPX file library. You must select the FPX file Row and use Batch Build to create the footprint. All SOT89 footprints use the mfr. recommended pattern. However, you could potentially create this footprint in FP Designer. |
