SOT353 with Different Pin 1 Orientation |
ChrisChris
Topic: SOT353 with Different Pin 1 OrientationPosted: 20 Feb 2022 at 11:22am |
I have a somewhat odd example of an SOT353 package with 2 different pin 1 cases as follows: ![]() I created the SOT353 with the Calculator and then cloned the part and renamed it SOT353-180D. I now need to customize this version by moving the pin 1 chamfer to the upper right without renumbering the pads. How would you recommend doing this? It does not seem like I can open a part in FP Designer that was created using the calculator. Is my only option to create this part from scratch in FP Designer? Thanks, Chris
ChrisChris
Posted: 20 Feb 2022 at 11:25am |
FYI... I checked and you have this part available for free in POD but it is wrong.
Pin 1 should be as I've indicated above in SOT353-180D. The part number is Diodes Inc. MMBD4448HCQW.
Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 6031 |
Posted: 20 Feb 2022 at 12:09pm |
I guess Diodes, Inc. has multiple pin configurations for their SOT-353. Very unusual for a top-rated component manufacturer.
Diodes does not call the Case Code for the MMBD4448HCQW part number SOT353-180D. Nor does it actually print the pin assignments in the MMBD4448HCQW datasheet - ![]() Here's another part number: ![]() |
Posted: 20 Feb 2022 at 12:19pm |
The Diodes part number series MMBD4448HCQW on POD will be updated by Monday morning with the new Case Code - SOT353-180D
Thank you for reporting this issue. |
ChrisChris
SOT-353-180D is my name, to differentiate the two. Anyway, the datasheet indicates case labeling will have a pin 1 marker, so assembly will be confused if I don't crate a custom part for this.
![]() So how should I handle this? Thanks, Chris |
ChrisChris
Posted: 20 Feb 2022 at 12:21pm |
OK, I will pull the part from POD on Monday when it's ready.
Thanks, Tom!
