  New Posts New Posts RSS Feed - Renumber pins in FP Designer
lalexman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Topic: Renumber pins in FP Designer
    Posted: 10 Oct 2014 at 7:33am
How can you renumber pins using the FP Designer ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2014 at 8:02am
If it's just a couple of pins you can change any pin name by double-clicking the pad to open the Properties dialog box, change the pin number and select OK. In the V2014.12 release you will be able to select the "Enter" key to close the Properties dialog box (right now you have to select the "OK" button to accept your new pin number).
If it's a row of pins, you might want to get the coordinate of the first pin and write it down and then delete the row. Select the pad stack, enter the coordinate, pin qty, pitch and correct pin number to replace the row. It's rather fast to re-insert pins if they're in a row.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2014 at 8:04am
Ok. Thanks . It would be nice to be have a renumber feature.
