  New Posts New Posts RSS Feed - OrCAD 17.2: END LAYER Regular Pad Is Undefined
shreyas.shroff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shreyas.shroff Quote  Post ReplyReply Direct Link To This Post Topic: OrCAD 17.2: END LAYER Regular Pad Is Undefined
    Posted: 14 May 2019 at 1:42am
We recently updated our OrCAD PCB-Editor to 17.2.
Now LE cannot build TH footprints anymore. The new Pad Stack Editor always throws up this warning:
This is the script that caused the error (just as an example, since all others behave the same way):
# Allegro script
# Generated by FPX Expert
#   name:       s218h145
QtSignal MainWindow New triggered
QtSignal fileNewDialog dataCombo CurrentIndexChanged "Thru Pin"
QtSignal fileNewDialog dataCombo activated "Thru Pin"
QtSignal fileNewDialog browse clicked
QtFillin s218h145.pad
QtSignal fileNewDialog OK clicked
QtSignal MainWindow Units CurrentIndexChanged Millimeter
QtFillin Yes
QtSignal MainWindow DecimalPlaces activated 4
QtSignal GuidedDrillTab HoleType activated Circle
QtSignal GuidedDrillTab holeXSize editingFinished 1.45
QtSignal GuidedDesignLayersTab LayersTable cellClicked 0 "Regular Pad" None 0 2
QtSignal GuidedDesignLayersTab PadShape CurrentIndexChanged Square
QtSignal GuidedDesignLayersTab PadShape activated Square
QtSignal GuidedDesignLayersTab PadWidth editingFinished 2.18
QtSignal GuidedDesignLayersTab LayersTable cellClicked 1 "Regular Pad" None 1 2
QtSignal GuidedDesignLayersTab PadShape CurrentIndexChanged Circle
QtSignal GuidedDesignLayersTab PadShape activated Circle
QtSignal GuidedDesignLayersTab PadDiameter editingFinished 2.18
QtSignal GuidedDesignLayersTab LayersTable cellClicked 1 "Thermal Pad" None 1 3
QtSignal GuidedDesignLayersTab PadDiameter editingFinished 2.3
QtSignal GuidedDesignLayersTab LayersTable cellClicked 1 "Anti Pad" None 1 4
QtSignal GuidedDesignLayersTab LayersTable cellClicked 2 "Regular Pad" None 2 2
QtSignal GuidedMaskLayersTab LayersTable cellClicked 0 Pad None 0 1
QtSignal GuidedMaskLayersTab PadShape CurrentIndexChanged Square
QtSignal GuidedMaskLayersTab PadShape activated Square
QtSignal GuidedMaskLayersTab PadWidth editingFinished 2.18
QtSignal GuidedMaskLayersTab LayersTable cellClicked 1 Pad None 1 1
QtSignal GuidedDrillSymbol FigureType CurrentIndexChanged Cross
QtSignal GuidedDrillSymbol FigureType activated Cross
QtSignal GuidedDrillSymbol FigureWidth editingFinished 1.0
QtSignal GuidedDrillSymbol FigureHeight editingFinished 1.0
QtSignal MainWindow Save triggered
QtSignal MainWindow Exit triggered
I have already checked the psmpath and psmpath settings and the both conatin the "." in the first place (although I don't think that this is the problem here, sinc SM Parts build correctly).
I am running LE2016.10
Any ideas how to fix this?
Regards
ShreyasCry
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2019 at 8:30am
Did you read the OrCAD PCB import instructions in the User Guide?
Did you select the OrCAD 17.2.048 translator?
We can do a webcast with you to get you running again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2019 at 8:36am
Suppress Drill Warnings.
User Guide: http://www.pcblibraries.com/products/fpx/userguide/default.asp?ch=206 Section 2.
chrisa_pcb View Drop Down
Moderator Group
Moderator Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2019 at 8:28am
Make sure after you installed 17.2, that you fully patched up to S052, which is the current, I believe.
You can check your patch level in Help -> About in either the Padstack Editor or OrCAD PCB Editor/Allegro. You should see an S (patch) level after the version callout.
You will also need to make sure the version in our tool is selected as 17.2.048. If you don't see that, you need to patch our tool to current also.
