  New Posts New Posts RSS Feed - Land Pattern / Solder Joint Goals
bsulzer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsulzer Quote  Post ReplyReply Direct Link To This Post Topic: Land Pattern / Solder Joint Goals
    Posted: 09 Sep 2019 at 4:05am
Hi everybody.
I am quite sure to remember the least toe value for rectangular end cap equal or lager than 0603 to be 0.15 mm (according to IPC-7351B).
from the library expert solder joint goal tables i get different values the bigger the components get (0603 already 0.2, 1206 & 1210 have a 0.25mm toe, and so on).
could anyone help me solve my confusion?
Cheers
Beat
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2019 at 6:56am
The Library Expert has IPC-7351B Solder Joint Goals in a Preference file in this folder -
C:\Program Files (x86)\PCB Libraries\Library Expert 2019
File Name: IPC-7351B_DefaultPreferences.dat
The Library Expert default Preference file was updated to conform to IPC-J-STD-001.
