  New Posts New Posts RSS Feed - IPC-7351C.opt File
IPC-7351C.opt File
ransonjd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ransonjd Quote  Post ReplyReply Direct Link To This Post Topic: IPC-7351C.opt File
    Posted: 09 Jun 2021 at 12:00pm
I took a look at the 7351-C.opt, and it changes some things that I wouldn't have expected. Are these intentional?
On TO92 and TOCyl
Pin1PadShape="Sqr"
instead of Pin1PadShape="Rnd" in the default preferences
Under <InwardL> the divisions are like
"<!--Height > 2.20 and <= 3.20 mm-->"
instead of
"<!--Pitch > 0.65 and  <= 080 mm-->"
Under <BGANC>
PasteMaskExcess="0"
instead of PasteMaskExcess="100" in the default preferences
Under <TH_Terminal_Options>
HoleSizeRound="0.05" and PadSizeRound="0.01" are missing
It's IPC-7351C.opt that I was looking at.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2021 at 1:39pm
TO-92 must have a round pin 1 pad shape because the corner of a square pad cuts into the silkscreen outline. WE just discovered this last week. We updated the IPC-7351C .opt file for the V2021.08 release.
There are two Inward L leads.
  • Inward Flat Ribbon L Lead = 2-pin Molded Body component family (requires Height)
  • Inward L-Lead = multiple pin SOL component family (requires pin pitch)
Post Options Post Options   Thanks (0) Thanks(0)   Quote ransonjd Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2021 at 7:48am
Looks like IPC-7351C.opt lists heights in the comments for the Gullwing SOT parts.
</GullwingSOT>
      <InwardL>
        <Applications>
          <Application_0>
            <!--Height > 4.20 mm-->
Are these changes intentional too?
Under <BGANC>
PasteMaskExcess="0"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2021 at 8:56am
I think I know what happened.
The IPC-7351C .opt file was created 2 months ago and there have been multiple updated to the Options since then and the IPC-7351C .opt file is corrupt and needs to be regenerated from scratch incorporating all the latest Option settings.
There will be a new IPC-7351C Option file in the next V2021.08 pre-release
Thank you for reporting this issue. We would have never known.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2021 at 9:38am
Here is the updated IPC-7351C .opt file - uploads/3/IPC-7351C.zip
Let us know if you still have issues.
pzt648485640 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pzt648485640 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2021 at 2:15am
Can you add support for ASSEMBLY_TOP labels value?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2021 at 8:34am
Not immediately but we'll put it on the to do list.
The next phase of V2021 development is to redesign all 25 CAD tool translator user interfaces and then rewrite all the translators. That process will take several months.
