IPC-7351 Padstack Naming Convention |
Page <1234> |
Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 6113 |
Posted: 05 Oct 2015 at 4:38am |
I guess we'll have to change the document to clarify the rule. Thanks for the heads up.
A square pad on an inner layer is useless. |
Matthew Lamkin
Posted: 05 Oct 2015 at 4:27am |
Cheers Tom,
So now I am being told your document should be changed as it is your document that is saying that they should be the same shape as on the outer layers. Which is contrary to both what you have explained and that the 2nd item suggests. They are either matching the outer layer shape or they are round. Inner Layer Land is the same shape as the outer layer land contradicts: The inner layer land shapes are Circular Because if the outer layer land is square and the inner layer land is the same shape as per the first default then it cannot be round as per the 2nd default. What is being suggested is that your statements in that are conflicting & hence confusing - perhaps the first one should not be used? |
Posted: 05 Oct 2015 at 4:18am |
Since the beginning g of multilayer PCB layout back in the 1970's the outer layer Pin 1 pad shape was square to indicate the Polarity Marking because there was no silkscreen. Otherwise all pad stacks would be round throughout the entire PC board.
There was no need to take up valuable board real-estate with square corner pads on the inner layer because you cannot see them anyway. 10 years later when CAD tools started to become popular the trend continued and that is the way Pin 1 pad stacks are created. i.e.: there is no other use for outer layer square pads than to indicate polarity and that is the "Default Pad Stack". Rookie designers ask these types of legitimate questions and the old timers have to explain: "Because that's the way it's always been done" (even though it breaks a pad stack naming convention rule in order to simplify the pad stack name). We're not going to break rank on this issue. |
Matthew Lamkin
Posted: 05 Oct 2015 at 2:17am |
I have someone asking a question about this.
To me it's obvious, the inner layer lands are always the same shape as the outer layer lands unless you deliberately change them to be something else, the default shape (unless there are overriding factors that require otherwise) is for the inner layer land to be circular. But it does not read as I have written it - it just reads conflicting. :) |
SteveD
Joined: 30 Oct 2013 Location: San Diego Status: Offline Points: 240 |
Posted: 23 Jun 2015 at 11:41am |
What is the terminal layer in a pad stack? And why do some components have it, and others do not?
chads108
Joined: 17 Oct 2012 Location: Plano, TX Status: Offline Points: 35 |
Posted: 20 Mar 2014 at 6:03am |
Any suggestions for naming multi-drill padstacks?
PLTcbv
Joined: 21 Aug 2012 Location: the Netherlands Status: Offline Points: 134 |
Posted: 08 Nov 2013 at 6:28am |
I have checked the latest version (2013.16) but the naming for the Chamfer Location is still not fixed.
![]() Still "Lower Left" and "Lower Right". Should be according IPC "Bottom Left" and "Bottom Right".
PLTcbv
Posted: 11 Sep 2013 at 2:06am |
I'm looking at 2013.12 and it looks like it was't fixed.
Nick B
Posted: 01 Sep 2013 at 4:31am |
This was fixed in 2013.11, to be released within the next couple days.
Posted: 21 Aug 2013 at 7:46am |
Once Jeff gets back from vacation in a week, we'll fix this padstack naming convention to match IPC-7351.
Thanks for reporting this! |
Page <1234> |
