Altium Script Recommendation
robmeyer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robmeyer Quote  Post ReplyReply Direct Link To This Post Topic: Altium Script Recommendation
    Posted: 03 Mar 2015 at 1:41am
I have one comment to the Altium Script feature.
Altium recommend to use pre and post processes in scripts with PCBServer usage.
So it would be nice to see in the CreateComponent Procedure this processes. For example:
Procedure CreateComponentSOD2613X115N;
Var
    NewPCBLibComp               : IPCB_LibComponent;
    NewPad                      : IPCB_Pad2;
    NewRegion                   : IPCB_Region;
    NewContour                  : IPCB_Contour;
    STEPmodel                   : IPCB_ComponentBody;
    Model                       : IPCB_Model;
Begin
    Try
    PCBServer.PreProcess;
    NewPCBLibComp := PCBServer.CreatePCBLibComp;
    CurrentLib.RegisterComponent(NewPCBLibComp);
    CurrentLib.CurrentComponent := NewPcbLibComp;
    Finally
    PCBServer.PostProcess;
    End;
    CurrentLib.Board.ViewManager_FullUpdate;
    Client.SendMessage('PCB:Zoom', 'Action=All' , 255, Client.CurrentView)
End;
It's not a big deal, but would be nice to see.
Robert
Post Options Post Options   Thanks (0) Thanks(0)   Quote robmeyer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2015 at 4:53am
Also nice to have would be this short entry in the prjsrc file.
For example:
[Generic_ScriptingSystem]
StartProcName=SOD2613X115N.pas>CreateALibrary
Robert
chrisa_pcb View Drop Down
Moderator Group
Moderator Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2016 at 9:45am
If using Post Process Scripting, simply click 'Use Post Process Script' and save it as a preference.
The prjsrc mod doesn't seem to gain anything. This pops the prj/pas files into the left window, right? But to actually run the script I still need to go DXP -> Run Script, so what do I gain other than confusion? If I see the files pop in the window, I expect to be able to do something with them, and I'm not seeing that. I'd like to keep the process as confusion free as possible but if you can convince me of the benefits i'll do it.
This page was generated in 5.484 seconds.
