Molded Body - Cap, Polarized Calculations
ccyman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ccyman Quote  Post ReplyReply Direct Link To This Post Topic: Molded Body - Cap, Polarized Calculations
    Posted: 13 Nov 2026 at 4:11pm
Is there perhaps a setting I need to fix in the calculator when using it out of the box for Molded Body - Capacitor, Polarized?
The toe and heel results are not what I'm expecting to see based on the settings defined.
Since I can't upload images, here's what the settings were:
Component dimensions filled in were (mm):
A = 2.00 max
b = 2.20 +/-0.2
D = 3.50 +/-0.2
E = 2.80 +/-0.2
L = 0.80 +/-0.3
Terminal Density Level
Inward Flat Ribbon L-Lead. Height > 1.20, <= 2.20 mm
Density Level = Nominal
Toe = 0.05 mm
Heel = 0.45 mm
Side = 0.00 mm
Calculator results are:
G = 1.33 mm
X = 1.63 mm
Y = 2.40 mm
This results in a toe of 0.088mm (I was expecting 0.05mm) and a heel of 0.442mm (I was expecting 0.45mm).
These results are from Footprint Expert 26 (26.10, 10/30/2026).
Cindy
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2026 at 8:43am
The Molded Body Toe is under the package.
The 0.05 mm Toe solder joint goal is the basic value in Options and the Tolerances are added to create the resulting value.
When using the Min/Max calculation Mode, solder joint goals + Tolerances = final pad protrusion.
This page was generated in 4.877 seconds.
