  New Posts New Posts RSS Feed - IPC-7352 Footprint Naming Convention: Through-hole
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: IPC-7352 Footprint Naming Convention: Through-hole
    Posted: 15 Aug 2026 at 11:00am
The land pattern naming convention uses component dimensions to derive the land pattern name.
The first 3 - 6 characters in the land pattern name describe the component family.
The first number in the land pattern name refers to the Lead Spacing or hole to hole location to insert the component lead.
All numbers that follow the Lead Spacing are component dimensions.
These characters are used as component body identifiers that precede the value and this is the priority order of the component body identifiers –
  • P = Pitch for components with more than two leads
  • W = Maximum Lead Width (or Component Lead Diameter)
  • L = Body Length for horizontal mounting
  • D = Body Diameter for round component body
  • T = Body Thickness for rectangular component body
  • H = Height for vertically mounted components
  • Q = Pin Quantity for components with more than two leads
  • R = Number of Rows for connectors
Notes:
All component body values are in millimeters and go two places to the right of the decimal point and no leading zeros.
All Complexity Levels used in the examples are "B".
Component, Category
Land Pattern Name
Capacitors, Non-Polarized Axial Diameter Horizontal Mounting
CAPAD + Lead Spacing + W Lead Width + L Body Length + D Body Diameter
Capacitors, Non-Polarized Axial Rectangular
CAPAR + Lead Spacing + W Lead Width + L Body Length + T Body thickness + H Body Height
Capacitors, Non-Polarized Axial Diameter Vertical Mounting
CAPADV + Lead Spacing + W Lead Width + L Body Length + D Body Diameter
Capacitors, Non-Polarized Axial Rect. Vert. Mtg.
CAPARV + Lead Spacing + W Lead Width + L Body Length + T Body Thickness + H Body Height
Capacitors, Non-Polarized Radial Diameter
CAPRD + Lead Spacing + W Lead Width + D Body Diameter + H Body Height
Capacitors, Non-Polarized Radial Rectangular
CAPRR + Lead Spacing + W Lead Width + L Body Length + T Body thickness + H Body Height
Capacitors, Non-Polarized Radial Disk Button
CAPRB + Lead Spacing + W Lead Width + L Body Length + T Body thickness + H Body Height
Capacitors, Polarized Axial Diameter Horizontal Mounting
CAPPAD + Lead Spacing + W Lead Width + L Body Length + D Body Diameter
Capacitor, Polarized Radial Diameter
CAPPRD + Lead Spacing + W Lead Width + D Body Diameter + H Body Height
Diodes, Axial Diameter Horizontal Mounting
DIOAD + Lead Spacing + W Lead Width + L Body Length + D Body Diameter
Diodes, Axial Diameter Vertical Mounting
DIOADV + Lead Spacing + W Lead Width + L Body Length + D Body Diameter
Dual-In-Line Packages
DIP + Lead Span + W Lead Width + P Pin Pitch + L Body Length + H Component Height + Q Pin Qty
Dual-In-Line Sockets
DIPS + Lead Span + W Lead Width + P Pin Pitch + L Body Length + H Component Height + Q Pin Qty
Headers, Vertical
HDRV + Lead Span + W Lead Width + P Pin Pitch + R Pins per Row + L Body Length + T Body Thickness + H Height
Headers, Right Angle
HDRRA + Lead Span + W Lead Width + P Pin Pitch + R Pins per Row + L Body Length + T Body Thickness + H Height
Inductors, Axial Diameter Horizontal Mounting
INDAD + Lead Spacing + W Lead Width + L Body Length + D Body Diameter
Inductors, Axial Diameter Vertical Mounting
INDADV + Lead Spacing + W Lead Width + L Body Length + D Body Diameter
Inductors, Non-Polarized, Radial Diameter
INDRD + Lead Spacing + W Lead Width + D Body Diameter + H Body Height
Inductors, Polarized, Radial Diameter
INDPRD + Lead Spacing + W Lead Width + D Body Diameter + H Body Height
Jumpers, Wire
JUMP + Lead Spacing + W Lead Width
Mounting Holes Plated with Support Pad
MTGP + Pad Size + H Hole Size + Z Inner Layer Pad Size
Mounting Holes Non-Plated With Support Pad
MTGNP + Pad Size + H Hole Size + Z Inner Layer Pad Size
Mounting Holes Non-Plated Without Support Pad
MTGNP + Pad Size + H Hole Size + Z Inner Layer Pad Size + K Keep-out Diameter
Mounting Holes Plated with 8 Vias
MTGP + Pad Size + H Hole Size + Z Inner Layer Pad Size + 8 Vias
Pin Grid Array’s
PGA + Pin Qty + P Pitch + C Pin Columns + R Pin Rows + L Body Length X Body Width + H Component Height
Resistors, Axial Diameter Horizontal Mounting
RESAD + Lead Spacing + W Lead Width + L Body Length + D Body Diameter
Resistors, Axial Diameter Vertical Mounting
RESADV + Lead Spacing + W Lead Width + L Body Length + D Body Diameter
Resistors, Axial Rectangular Horizontal Mounting
RESAR + Lead Spacing + W Lead Width + L Body Length + T Body thickness + H Body Height
Single-In-Line Packages
SIP + Body Width + W Lead Width + P Pin Pitch + L Body Length + H Component Height + Q Pin Qty
Test Points, Round Land
TP + Lead Width
Test Points, Square Land
TPS + Lead Width
Test Points, Top Land Round & Bottom Land Square
TPRS + Lead Width
Wire
PAD + Wire Width
