IPC-7351 Padstack Naming Convention
 Post Reply Post Reply Page  123 4>
Post Options Post Options   Thanks (2) Thanks(2)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: IPC-7351 Padstack Naming Convention
    Posted: 31 Mar 2012 at 5:46am
INTRODUCTION
The padstack consists of combinations of letters and numbers that represent shape, or dimensions of lands on different layers of printed boards or documentation. The name of the padstack needs to represent all the various combinations. These are used in combination with the land pattern conventions defined herein according to the rules established in the IPC-2220 Design standards.
The first part of the padstack convention consists of a land shape. There are six basic land shape identifiers. Note: All alphabetical characters are “lower case”. This helps discriminate numeric values.
Basic Land Shape Letters
c = Circular
s = Square
r = Rectangle
b = Oblong
u = User Defined Contour (Irregular Shape)
d = D Shape (Square on one end and Circular on the other end)
Padstack Defaults
  • Solder Mask is 1:1 scale of the land size
  • Paste Mask is 1:1 scale of the land size
  • The Assembly Layer land is 1:1 scale of the land size
  • Inner Layer Land is the same shape as the outer layer land
  • The Primary and Secondary lands are the same size
  • The inner layer land shapes are Circular
  • Vias are Circular
  • Thermal ID, OD and Spoke Width sizes follow the IPC Level A, B or C
  • Plane Clearance Anti-pad size follows the IPC Level A, B or C
  • Thermals have 4 spokes
  • Mounting Holes are Circular
Note: Every board fabricator’s ability to register solder mask is different.  The 1:1 scale solder mask covers the variation, and so long as manufacturers are building to specs such as IPC-6012 that say you can’t have mis-registration of the solder mask.
Illegal characters that cannot be used (Microsoft requirement) include “ ” , ; : / \ [ ] ( ) . { } * & % # $ ! @ ^ =
Examples utilizing the padstack naming convention (all values are in metric units)
Note: Every number goes two places to the right and as many as needed to the left of the decimal
Examples: 1150 = 11.50 mm or 11500 μm, 150 = 1.50 mm or 1500 μm, 15 = 0.15 mm or 150 μm
c150h90 where “c” denotes a Circular land with a 1.50 diameter and H denotes a hole size of 0.90
c130_95 Donut pad where “c” denotes a Circular land with a 1.30 OD diameter and 95 denotes the ID diameter
c130_95hn Donut pad - “c” denotes a Circular land with a 1.30 OD diameter and 95 denotes the ID diameter and hn70 denotes hole, non-plated 0.70 diameter
c130_95hn70k147 Donut pad - “c” denotes a Circular land with a 1.30 OD diameter and 95 denotes the ID diameter and hn70 denotes hole, non-plated 0.70 diameter and k147 denotes a keep-out 1.47 diameter
v50h25 where a “v” denotes a via with a 0.50 land (default Circular land) and H denotes a 0.25 hole
s150h90 where “s” denotes a 1.50 Square land and H denotes a hole size of 0.90
s350 where ‘s” denotes a square SMT land size of 3.50
r200_100 where “r” denotes a Rectangular SMT land 2.00 land length X 1.00 land width
b300_150 where “b” denotes a SMT Oblong land size of 3.00 X 1.50
b400_200h100 where “b” denotes an Oblong land size of 4.00 length X 2.00 width and 1.00 hole
d300_150 where “d” denotes land with one circular end and one square end (looks like a D) 3.00 X 1.50
v30h15l1-3 where “v” denotes a 0.30 blind via with 0.15 Hole; 1 is the starting layer, 3 is the end layer
r200_100r5 = Rounded Rectangular 2mm X 1mm X 0.05mm radius corners
r200_100c10 = Chamfered Rectangular 2mm X 1mm X 0.1mm chamfered corners
v30h15l3-6 where “v” denotes a 0.30 buried via with 0.15 Hole; 3 is the starting layer, 6 is the end layer
The through hole “IPC-7251 Padstacks.xls” file should be used as the basis for a new chart in IPC-7251 and IPC-7351B.  Note: Draft supporting paragraphs with formula that document the math involved.
It is assumed that the padstack has the same value as the mounted layer size and shape for –
  • Inner Layer
  • Opposite Side
  • Solder Mask
  • Solder Paste
  • Assembly Layers
It is also assumed that the “Plane Clearance” and “Thermal Relief” data follows the through-hole convention guidelines defined in the IPC-2221 and IPC-2222 standards.
Modifiers that are used when padstack features are different than the defaults
These are the “Variants” or “Modifiers” that go after the basic padstack naming convention.
These are used when the User needs to change the padstack default values either by a different dimension or a different shape. In instances where shapes are different this becomes a two letter code with the modifier first followed by the land shape letter.
n = Non-plated Hole
z = Inner Layer land dimension if different than the land on primary layer
x = Special modifier used alone or following other modifiers for lands on opposite side to primary layer land dimension
t­ = Thermal Relief; if different than IPC standard padstack – tid_od_sw for 4 spoke default
m = Solder Mask if different than default 1:1 scale of land
p = Solder Paste if different than default 1:1 scale of land
a = Assembly surface land if different than default 1:1 scale of land
y = Plane Clearance (Anti-pad) if the value is different than the Thermal OD
o = Offset Land Origin
k = Keep-out
r = Radius for Rounded Rectangular Land Shape
c = Chamfer for Chamfered Rectangular Land Shape
Shape change is the last letter in the string prior to the dimension.
Other usage of the padstack naming convention
USE of letter v: Vias can be named using the padstack naming convention. Because most vias use lands that are circular in shape, the letter V will be used in place of the letter C in the padstack naming convention. If this is not true the modifiers can be added after the letter V to signify shape or dimensional changes to this default.
USE of letter w: In addition to Vias the padstack naming convention can also be used for defining mounting holes. The letter W shall be used to define the mounting hole characteristics and any associated lands used for the surface lands (either plated or un-plated)
Examples of double character modifiers:
ts = Thermal Square; if different than the top side land shape and dimensions
sw = Thermal spoke width
zs = Inner Layer Land Shape is Square (Note: The default is circular)
m0 = No Solder Mask
mxc = Solder Mask Opposite Side Circular
mx0 = Solder Mask Opposite Side No Solder Mask
xc = Opposite Side Circular
vs = Via with Square land
hn = Non-plated Hole
Modifier Example for Through-hole:
s150h90zs150 = where “s” is Square 1.50 land with 0.90 Hole with 1.50 inner (Z) Layer Square land
c150h90zc150 = where “c” is Circular 1.50 land with 0.90 Hole with 1.50 inner (Z) Layer Circular land
Modifier Examples for Vias:
vs50h25 where “vs” denotes a 0.50 Square Via with a 0.25 Hole
v50h25xs70 where “v” is 0.50 Circular Via with 0.25 Hole and 0.70 Square land on opposite side
Chamfered & Rounded corner modifiers are used to indicate which corner(s) are modified.
Order of precedence has been given to the first 4 modifiers.
Modifiers:
bl – bottom left
br – bottom right
ul – upper left
ur – upper right
ulr – upper left & right
blr – bottom left & right
ubl – upper and bottom left
ubr – upper and bottom right
Rounded and Chamfered lands in “one corner” Modifier Examples:
r100_200rbl50 = rectangular land 1.00 x 2.00 with 0.50 radius for rounded corner in bottom left corner
r100_200rbr50 = rectangular land 1.00 x 2.00 with 0.50 radius for rounded corner in bottom right corner
r100_200rul50 = rectangular land 1.00 x 2.00 with 0.50 radius for rounded corner in upper left corner
r100_200rur50 = rectangular land 1.00 x 2.00 with 0.50 radius for rounded corner in upper right corner
r100_200cbl50 = rectangular land 1.00 x 2.00 with 0.50 chamfer for chamfer corner in bottom left corner
r100_200cbr50 = rectangular land 1.00 x 2.00 with 0.50 chamfer for chamfer corner in bottom right corne
r100_200cul50 = rectangular land 1.00 x 2.00 with 0.50 chamfer for chamfer corner in upper left corner
r100_200cur50 = rectangular land 1.00 x 2.00 with 0.50 chamfer for chamfer corner in upper right corner
Examples of a square land with 3 rounded and 1 chamfered corner (for Thermal Pad)
s300p190r25cul50 = square 3.00 land, square paste 1.90, corner radius 0.25, upper-left chamfer 0.50
s300p190r25cbl50 = square 3.00 land, square paste 1.90, corner radius 0.25, bottom-left chamfer 0.50
Chamfered and Rounded Rectangular with all four corners chamfered does not need a corner modifier.
Modifier Examples with Rounded Rectangle Land Shape:
r200_100r50 = rectangular land 2.00 x 1.00 with 0.50 radius for rounded corners in all 4 corners
r200_100c50 = rectangular land 2.00 x 1.00 with 0.50 chamfer for chamfered corners in all 4 corners
Examples of a padstack with Circular land with hole using various modifiers
c150h90 = Default padstack with a 1.50 circular land with a 0.90 hole (no modifiers used)
c150hn90 = Default padstack with a 1.50 circular land with a 0.90 non-plated hole (no modifiers used)
c150h90z140 = Inner layer land is smaller than external lands 1.40 or 0.10 smaller
c150h90z140x170 = Opposite side land is larger than top side land 1.70 or 0.20 larger
c150h90z140x170m165mx185 = Solder mask opening for top and bottom lands 0.15 larger for each
c150h90z140x170m165mX185a200 = Assembly drawing land in 0.50 larger than 1.50 primary land
c150h90z140x170m165mx185a200y300 = Plane clearance anti-pad diameter is 3.00
c150h90z140x170m165mx85 = Solder mask encroachment on opposite land by 0.65 smaller
c150h90m165 = adding a solder mask opening of 1.65 diameter or 0.15 larger than land
c150h90t150_180_40 = Thermal ID 1.50, OD 1.80, Spoke Width 0.40, Anti-pad 1.80
c150h90t150_180_40y200 = Anti-pad 2.00 (because the size is different than the Thermal OD)
c150h90t150_180_80_2 = Spoke Width 0.80 with 2 Spokes
c150h90m165t150_180_40 = Solder Mask 1.65
Examples of a padstack with Oblong land with Slotted Hole
Sample – b = Oblong Land Shape then “X” dimension (length) then Underscore _ “Y” dimension (width)
b400_200h300_100 = Oblong land 4mm length X 2mm width with slotted hole size 3mm X 1mm
b400_200hn300_100 = Oblong land 4mm X 2mm with non-plated slotted hole size 3mm X 1mm
Examples of a SMT padstack land using various modifiers
b300_150 = Default padstack with a 3.00 length and 1.50 width land (no modifiers used)
b300_150m330_180 = Solder Mask is 0.30 larger than the land on all sides
b300_150m330_180p240_140 = Solder Paste is smaller by 0.10 width and 0.60 length
b300_150b-50 = Oblong Land 3.0mm X 1.5mm w/Offset Origin negative 0.5mm
r400_200po430_230 = Rectangle SMT land 4.00 X 2.00 with a Oblong Solder Paste size of 4.30 X 2.30
Example of Thermal Pads for QFN, SON, QFP and SOP
Square Configurations
s480p4s152 = 4.80mm Square Land with 4 Paste Mask Squares 1.52mm each
s480p4s152cul50 = 4.80mm Square Land with 4 Paste Mask Squares 1.52mm each with 0.50mm Chamfer in Upper Left corner
s480p4s152cul50r25 = 4.80mm Square Land with 4 Paste Mask Squares 1.52mm each with 0.50mm Chamfer in Upper Left corner with 0.25mm corner Radius
Example of a Mounting Hole
w700h400z520m720 = This is a Plated Through Mounting hole for a #6-32 screw using a 4.00 diameter hole and having a circular 7.00 land on the primary and secondary side of the board, with a solder mask clearance that is 0.20 larger than the 7.20 land. The internal lands are smaller that the external and are also circular 5.20 in diameter.
w700hn400z520m720 = Non-plated version
Example of a Local Fiducial for Fine Pitch SMT Components
c100m200k200 = Circular Land 1.00 with Solder Mask 2.00 with Keep-out 2.00
s100m200k200 = Square Land 1.00 with Solder Mask 2.00 with Keep-out 2.00
Example of Proportional Plated Through-hole padstack
c150h100 = 1.5mm circular pad with 1mm hole with 1.5mm solder mask with 1.5mm plane clearance with 1.5mm assembly outline with Thermal Relief w/4 spokes 0.4mm width with ID 1.5mm and OD 1.8mm
Example of Proportional Non-plated Through-hole padstack
c100hn150 = 1mm circular pad with 1.5mm hole “non-plated” with 1.5mm solder mask with 2.35mm plane clearance with 2.1mm keep-out
DaveCowl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCowl Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2012 at 4:24pm
I need a circular pad that does not have a paste shape since the part is not soldered down, rather it is a 'compression' fit.
What should the pad be named?
c40p0 ?
Cheers!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2012 at 10:50am
That's correct! 0 = No Paste
budnoel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote budnoel Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2012 at 7:53am
I thought I saw a rule stating that the padstacks should be rounded up to the nearest .05mm  All of the proportional through-hole PS are in multiples of .05mm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2012 at 11:42am
Through-hole padstack technology is currently still in the 0.05 mm resolution while SMT technology has advanced to the 0.01 mm resolution.
The primary driver behind SMT high resolution is the introduction of microminiature component packages and component lead terminal sizes.
It's difficult to miniaturize through-hole component technology however, when we release the new "Package Editor" in February, the user will have 100% control of customizing padstack generation.
So the current 0.05 mm through-hole resolution is compatible with the unreleased IPC-7251 standard but the resolution will shift when non-standard through-hole library solutions become available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCowl Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2013 at 11:06am
Is there a naming convention where the internal layer pad of a via is different from the top layer?
I need one that is v25h10l1-2 but on layer two the pad is '20', not '25'...
Cheers! Dave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2013 at 12:29pm
Yes, it would be very similar the the Padstack Naming Convention.
You're on the right track.
Go here to download the Padstack Naming Convention (and many other docs) -
PLTcbv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PLTcbv Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2013 at 1:26am
How do we create a correct padstack name for a " Pad 2.7 mm with a Hole Rnd 2.0 +Tol 0.1 -Tol 0 mm"
So how do we define hole tolerances in padstack names?
Regards,
Wim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2013 at 6:50am
IPC-7351B introduced the padstack naming convention.
There was no consideration to add the "hole tolerance" to the padstack name.
You would have to append the padstack name at the end and since there is no standard for how to represent this, you can invent your own.
My recommendation would be a double character modifier like "ht" (hole tolerance) and then the range.
You don't have to include the units as everything is considered metric (millimeters).
matthelm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote matthelm Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2013 at 12:25pm
Tom,
A few suggestion for the NEXT spec for padstack naming convention.  (Tom, you've done a great job, these are ONLY suggestions)
1. Use um for the base unit.  This way the spec can go smaller when needed, and you don't need to worry where the decimal point goes, as there isn't any.
2. Support leading zeros.  This is mainly so the names sort correctly for human interaction.  I'm really getting tired of seeing list in 3 different orders, depending on what tool/system is viewing them.  You will hit a few exceptions (I currently use 4 in um and 3 in mils, and I have a few inch based pads (maybe 10) over 3 digits , but I'd rather have that, than all my 10 mil and 100 mil and 11 and 100 mil, etc. pads near each other.
A software converter could handle both of these easy, as all you would be doing is adding a Leading/trailing zero, or this could easily be a switch only used when creating the pad, not in storage.  BTW, for dimensions in part names, I use the same system, but add 1 digit (5 & 4) on each unit.  It works very well for me.  I don't think I've had any parts fall out of the standard names.
This page was generated in 7.625 seconds.
