  New Posts New Posts RSS Feed - Naming Convention Example SOT23
vdamico7 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vdamico7 Quote  Post ReplyReply Direct Link To This Post Topic: Naming Convention Example SOT23
    Posted: 07 Aug 2024 at 1:50am
In the document:
Guidelines taken from IPC-7351 Footprint Expert Land Pattern Naming Convention;
the SOT23 naming convention is this:
SOT23 .........SOT23 - Pin Qty. + P Pitch _ Lead Span X Body Height + L Lead Length
but in the SW PCB expert (I'm using the demo version) the example of a SOT23 component (part number REF3318AIDCKT) is the following:
SOT23-3P65_210X110L36X22
I don't understand the meaning of the 4 last digits (36X22)
I imagine that 36 takes reference to L Lead Length and 22 to Lead Width, but in the datasheet these two values are different:
Lead Length range is: 0.20 - 0.60
Lead Width range is: 0.30 - 0.50
so I don't understand why in the SW the final digits are (36X22)
I'm missing something or there is other rule for the naming convention that I'm not following?
Best Regards
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2024 at 7:15am
The L dimensions are Nominal.
Here is the datasheet for the TI Case Code DCK0003A
Post Options Post Options   Thanks (0) Thanks(0)   Quote vdamico7 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2024 at 8:15am
Ok ok, the difference is that you are seeing the measures of SOT-SC70 and I'm seeing the measures of SOT-23 in the datasheet.
I saw that the PN details, in reality, the REF3318AIDCKT is a SOT-SC70.
At first, I saw the SOT-23 indications directly on the datasheet, because the physical description in the SW of the part number indicates an SOT-23.
Thanks!!Tongue
