Forum Home Forum Home > PCB Footprint Expert > Features & Training > FP Designer
Footprint Expert: Standards & Naming Conventions
    Posted: 21 Oct 2024 at 9:30am
  • IPC-7351B
  • IPC-7352
  • PCB Libraries (IPC-7351C)
  • Your Custom Footprint Name
Example:
QFN w/Thermal Pad
This page was generated in 2.345 seconds.
